des, that pad your using is a pass through. if 4s pack, 4s goes through. You want the cam on the cam pads, pr, ground and the yellow. i bail the white wire all together. same with the vtx, power comes off the corresponding power, ground and signal pads. anything other than that isn't powered through the core
i also didn't understand sebas vtx side.... that only has enough power to run a vtx,,,, and that's it. no other powe should be getting sucked off that side. Core has 2 seperate power supplies on it, tou use them both ou gotta wire it like it says to on the board.
that picture from trappy has a weird wire job, the white one is where the power is......
