Thanks all with the help. I will highlight some of the equipment again and highlight the issues along with some work I have done.
the transmitter is a Spektrum dx9, with a AR 9020, the XA controller, KDE ESC UAS 35, dualsky xm4010mr-6.5, all powered from a power distro board... The ESC's and the XA are soldered to the board. With a Max Amps 5450 4s battery. Power to the Spektrum RX is from the XA.... Again the motors are beeping with the them connected and disconnected to the xa. I have changed the throttle endpoints to 125. I have done the XA throttle calibration. I have sent a note to KDE to see if they have an idea. I'm waiting to hear from Drew at XA to see if he has an idea. The transmitter was set up by Drew.
When I was using the ztw spider ESC the motors were not beeping, but the setup wouldn't arm even with the calibration. So I decided to go with the KDE brand which created another hiccup.
Im wondering about the lack of the XA tone at start up... But the led indicator is working and I can go into calibration mode so I can think the issue is the XA controller is having an issue due to the motors and the beeping.
Couple questions.... If I did a calibration on the ESC would it do damage to them since the ESC are auto calibrated from what the company says.
What should I expect if I put an ESC servo cable into the Spektrum RX throttle position?
thanks all for the help!
http://youtu.be/B-U6YVoeFPc
