Thanks for the link tundra. I actually always understood the principal of the OPTO from using optical compressors (limiters really) in audio. But I never owned OPTO ESCs.
When you are talking about "one not having a BEC" it leads me to believe you actually have non-OPTO ESCs but that a few came without the BEC, since only one is needed to power the FC. That's what I've done with my other builds - removing the redundant wires from the other ESCs so that just one provides the necessary power/ground.
Even on my multiwii board, which needs power (many get it from a BEC), I run a UBEC. To provide a more constant, consistent power to the board, since the BEC can be lower than theFC really wants to see after draw-down. Providing 6v gves the multiwii about 5v across the Vin, and even that can be close to dropping close to the acceptable level if you run a lot of peripherals.
With the superx, since it has it's own power, I knew I didn't need the BEC. But I was under the impression that the red (+) wire was what triggered the OPTO ESC to know that signal was headed it's way. RT cleared that up - and it appears the signal wire alone can open the optical circuit.
Problem em with my set up was that the damn signal was too low. So the OPTO refused to accept the throttle signal. I will wait for testing to see how I feel about these hobby wing platinums, but I can tell you already I find them to be ornery and prissy
