One other thing you can try, set the end point travel on your low end of the throttle channel to around 125 (or -125 depending on the radio) and do the stick calibration thing all over again after resetting the SuperX to default settings. Drew posted the way to do that somewhere in this very thread as I recall. Also do a factory reset on the ESCs before you hook them up and make sure to do all the SuperX calibrations again after resetting it making sure the low throttle endpoint is at least at 100 or lower (higher number). What that should do is tell the SuperX it's low throttle signal needs to be lower than whatever it's at now and that SHOULD allow the ESCs to initialize.
If this were a SimonK ESC I could build you a couple different hex files with higher and lower throttle endpoint numbers to see which ones work. I ran into this exact same problem first time I hooked a set of SimonK ESCs to a NAZA which has a ridiculously low throttle output setting. Thought the Naza was bad but going back to standard ESCs worked, swap back to SimonK not working. Change the low throttle variable in the SimonK code, recompile and flash to ESC, bingo, they worked.
