thanks Jeff. I had switched back when drew confirmed it should be standard. Miscommunication between he and I. Figures that's the only thing that stopped the annoying beep.
Problem now is - decided to test the superx back on the other quad/Tx/RX/ESC(with BEC) setup where it worked before. No dice. Same thing as the hex (without the beeps). It starts up. Does it's dance. LED starts showing flight mode correctly etc. no motors/throttle response.
Perhaps the update to Standard went amiss? No idea.
I thought stepping ping away from it last night was a healthy move. Maybe I didn't step FAR enough away???![]()
i have almost same problem i bought another superx put it on my qav 400 30 amp simon k with bec esc and it starts but it's not stable even when i put in xscope so i forgot to take the red wire out from the esc should take that out since you don't need it . now i try to put it on the 650 v4 with hobby wing esc and now i have 3 motor beeping and only motor 3 runs not sure if the red wire ruin the controller v02 but that my problem now . I change to naza m and it working fine so there some thing i did to the super x i order another controller v02 box hoping it's will fix it.Maybe the red wire short the controller even alishamo from youtube say if you have bec esc must take the red wire out and if you have opto no.Today i will try to put it back on my qav 400 with simon k and red wire out.
