Good videos and I'll give you a 4 million credit However, I understand expo as it relates to elevators, ailerons, flaps and all those other things that go up and down, not a problem, understand the concept and application! what I don't understand is how expo relates to a propeller and or motor thrust!
David
Has nothing to really do with the thrust, your FC takes care of that, all your stick movement has to do with is basically the angle of the craft and the amount of movement it is expected to perform. (Yes it involves thrust, but again, not directly, you are mearly telling the FC a directional command the FC decides how much thrust and where)
What expo does for your multirotor is soften the response around zero stick.
So instead of “throw” think of it as resolution.
If your stick is at ZERO (center) and can be moved to the right to go right from 0 - 100 at linear setting (no expo) and each point of the stick position has 10 points of resolution you would end up with a total of 1000 points of resolution from 0 to full right 100.
So with a linear setting (no expo) 50% right stick throw would have used 500 points of resolution to reach 50% of the available stick throw.
But by adding 50% expo (negative expo in most cases except JR which is + for some unknown dumb reason), you are now shifting these points of resolution. So to get to get to 50% of the available stick throw you are now using 666.3 points of resolution meaning you have to move the stick further to get to 50% of the throw. This softens the the stick. so you can really smooth out the flight.
The only downside is that the remaining part of the stick has less resolution so from 50% stick throw to 100% at 50% expo you only have 333.3 point of resolution. So max throw comes a lot quicker after you get past the “expo’ed” area.
But since most people who add a higher number of expo don;t BANG the sticks this never is a problem and the over all result is a much smoother flight.
hope this helps...
PS.. the points of resolution was just an example, as it’s a bit more complicated than that, BUT.. most radios have like 2048 points of resolution some a bit more.. but 1000 was a nice easy round number.
