Was that the one the hit the creek?![]()
i lost the voltage regulator that was used for the hfp... you can't or wasn't recomended to go straight 6s into it. the osd will never be right running on a bec, it'll show 16 volts or whatever you set it to till it's in the ground.....
I asked Ben at Hoverfly a while ago about 6S and he said there is a workaround. You could use a 3S or 4S to run the board and power the motors with 6S. Seems simple enough.
Hoverfly "Livesky" tethered multicopter.
It's not just a flying polecam but IT'S NOT A UAV and wont be subject to the regulations.
Well done Hoverfly for thinking outside the square! It will make the tethered helium balloon cams redundant.
Do we know what altitude it will hover (for ever) at?
Pete
Board | Open Source | Gyro Stabilization | Self Leveling | Care Free | Altitude Hold | Position Hold | Return Home | Waypoint Navigation | Pricing |
AeroQuad 32 | Yes | Yes | Yes | Yes | Add-on | Add-on | Add-on | Medium | |
ArduCopter (APM 2.5) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Medium |
AutoQuad v6.6 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | High |
Crius All In One PRO | Yes | Yes | Yes | Yes | Yes | Add-on | Add-on | Add-on | Low |
Crius MultiWii Lite | Yes | Yes | Yes | Low | |||||
Crius MultiWii SE | Yes | Yes | Yes | Yes | Yes | Low | |||
DJI Naza | Yes | Yes | Add-on | Yes | Add-on | Add-on | Medium | ||
DJI Wookong | Yes | Yes | Yes | Yes | Yes | Yes | Add-on | High | |
Free Flight | Yes | Yes | Low | ||||||
FY-30A | Yes | Yes | Medium | ||||||
Gaui GU-344 | Yes | Medium | |||||||
Hobbyking KK2.0 | Yes | Yes | Yes | Low | |||||
HoverflyPRO | Yes | Yes | Add-on | Yes | Add-on | Add-on | Add-on | High | |
HoverflySPORT | Yes | Add-on | Medium | ||||||
KKMulticopter | Yes | Yes | Low | ||||||
MikroKopter Flight-Ctrl | Yes | Yes | Add-on | Yes | Add-on | Add-on | Add-on | High | |
MultiWii PRO / MTK GPS | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Low |
MultiWii PRO 2.0 / MTK GPS | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Low |
OpenPilot CC3D | Yes | Yes | Yes | Low | |||||
Paris MultiwiiCopter | Yes | Yes | Yes | Yes | Yes | Add-on | Add-on | Add-on | Medium |
Quadrino ZoomFlight | Yes | Yes | Yes | Yes | Yes | Medium | |||
Rabbit | Yes | Yes | Yes | Add-on | Add-on | Add-on | Low | ||
SmartAP Autopilot | Yes | Yes | Yes | Yes | Yes | Yes | Yes | High | |
TMF Pro FH-X46 AQ50 | Yes | Yes | Medium | ||||||
UAVP/UAVX | Yes | Yes | Yes | Yes | Yes | Yes | Add-on | Add-on | Low |
XAircraft FC1212-P | Yes | Add-on | Add-on | Add-on | Add-on | Add-on | Medium | ||
Zero UAV YS-X6 | Yes | Yes | Yes | Yes | Yes | Yes | High |
"With regards to the HoverflyGPS: We have been improving the performance, but a lot of what makes this technology work is antenna performance. Until recently, we have been using a MediaTek product which is the most cost-effective perfomance out there. However, its performance can be hampered by electronic noise, requiring mast-mounting and other precautions. That makes it somewhat temperamental to work with and accounts for a lot of the issues that have been seen over the past year.
Right now we are working with the Ublox LEA-6, which has a built-in filter to eliminate the electronic noise that has plagued our previous antennas. The down side is that the LEA-6 is a very different animal than anything we have previously used. It requires specific firmware on both the antenna and the boards, and a custom-made cable to communicate with the board. This is a big time sink, so we haven't been able to offer this solution commercially quite yet.. "
In my mind, every pilot should be able to fly in manual mode or not try AP until they can do that competently and seamlessly. I could go further and demand at least competent Heli flying first, but that is easy for me to say having flown RC Helis for 27 years:
I'm calling BS on this one.
