BorisS
Those Red Bulls are looking strong. When you say Mclaren have lost the best driver, did you mean Alonso or Vettel? Just kidding. I know you meant Hamilton.
Back to the subject of the S800. I do own the S800 and Z15g. While I don't think it is perfect, I do think it works very well out of the box. The vibrations are a bit worrisome and the gimbal does have some odd initialization behavior. That being said, the system masks those problems very well. I also think DennyR's prop adapters will go along way to reducing the vibes. I just received mine and will be trying them in short order.
Here are some issues I have seen:
The minimum yaw rate for the WK-M needs to be a bit slower. When operating the Z15 in orientation lock mode, the yaw is too fast.
The Z15 video converter does not work with NTSC, only PAL
The props do lend themselves to vibrations either from their construction or aerodynamics. I occasionally get harmonics at different RPM's. Yes I have balanced them on a magnetic balancer in all orientations.
Initialization on the Z15 is not consistent. It does seem to correct itself after a short time.
The landing gear need to be retractable.
Forget balancing the original props. Even if balanced perfectly they have a tracking problem thus will always cause vibrations etc. It was announced somewhere that DJI themselves are looking into different props now. The same ones are available at himodel for a 1/3 or the DJI price by the way ! Already had the HImodel version in hands and they are the same !
Concerning the startup routine just noticed the same. Had a second GH2 Z15 at my place today and although the same FW they do a different dance ! One of the Z15 Gh2 actually also changes the way it calibrates itself, its always a little different. My GH2 Z15 always does the same routine thus strange one.
retractables were already shown at the photokina and will be released soon by DJI. Question though if for the GH2 version especially they make any sense. In 108050I I would try to avoid a lot of panning around.
Concerning the Horizon level issue/speculation, I personally think its a little silly to pull out two videos were we have no background info how it was used, trims correct on the Radio, maybe gave a slight roll input during panning or tilt however the radio is setup etc. and stamp the zenmuse to have an issue staying level. Especially because all these were running on an old FW !
Boris
