ChopperAddict
OK, I am a newbie to MRC's, but I do understand wiring, radio binding and setup, and all the other things a long standing helicopter pilot would know, but my brand new F450 + NAZA has got me beat right now ?
Basically, I have just build the F450 - no problems, done all the wiring as per the diagrams etc. Whatever I seem to do when I connect a lipo to it all I get is a single beep every second or so. My AR9000 Rx (with 2 satellites attached) does not light up as it should, and the NAZA software clearly does not see the system depite it being plugged into the USB. Even the LED on the USB adaptor unit does not come on. ??????????????
I disconnected the AR9000 completely, rebound it successfully using a secondary BEC as power supply, double checked it was bound OK and then took the Throttle power ONLY from the NAZA to the AR9000. Powered up Tx first, then NAZA, but got the same result exactly.
Got me totally beat as the docs are not too helpful on troubleshooting so any help out there in Forum land would be very well received. I am sure it must be something simple, but I cannot get any further right now.
Ian
Ian
