Lanzar
Tnx for anwser. I had a new picloc with 056 alredy instaled so it was fresh. And no luck with flasing it with previous version. Will try reset later on to see if i can do it.
The latest beta firmware is 56.72. I tried it and there was no change. All three axes twitched occasionally, but predominantly Tilt and Roll, and Roll kept gently moving around.
HOWEVER, following a suggestion from George, at one point the camera mount was powered up WITHOUT the Tx. This results in Picloc stabilising the mount using its saved parameters, although obviously the mount cannot be controlled. Under these circumstances there was no twitching and pretty much no hunting. But, as soon as the Tx was turned on ... Twitch'n'Hunt came back to town.
A total mystery, as this does not happen with any of the versions prior to v.56.
So, it was back to HD55. But even then a new issue arose in the form of the mount wandering off-centre and then freezing. This was whilst airborne. Switching PL off and back on again with the AUX1 switch jerked everything back to centre and all operated normally for a while until the same thing happened. Wander off and freeze.
This is new. I have not seen this behaviour before.
As to your request for a solution, if I understand your question correctly you are getting the Error Message about such and such parameter being too high? Don't forget that there are several FW v55 variants and that each has its own respective Toolz application, but this Error Message can appear if you go backwards and use an earlier firmware version without doing a Factory Reset. In such instances, open Toolz, deselect Continuous Updates, click Connect and wait for the blue or orange line to appear briefly, and then click Factory Reset/Restart.
It is always prudent to have settings noted down for quicker programming after a Factory Reset. Although, I have found that, after trying countless firmware versions with Factory Resets, I can run through the basics in less than two minutes from memory! It reminds me of the earlier Piclocs that were programmed using a single push-button. I became so fluent that I could zip through the sequences of push-button clicks in next to no time!
