Thanks Aliexei, are you based in the UK too? How much was it, I don't recognise the currency on that site.
Also I was thinking about getting the 3x standard rather than the pro, does anyone know if the standard suffers from drift or is that still ok? I'm only stabilising roll and tilt on an AV130.
Andrew the website URL ended in .CH = Switzerland, therefore I'm sure it will be in Euros. Hope that helps
Ross
A small education for all you islanders. Switzerland never joined the Euro so Aerodron's price will be Swiss Francs or CHF (Confederation Helvetica Franc).
That's OK. It's free this time.
After some tweaking now it starts to work. it is a bit labor intensive, it works I use tools E055, and without servo connected you can chance parameters and store them in the eeprom, disconnect usb and connect the servo's an do the test. and so on. All are bench tests, later tests while flying.
There is now 55 fw on th pl. the toolz I use is vE055. Version v.HD3x_H055 from George site crashes after 10 seconds and leaver piclock unaccesble. The gimabal is a av200pro.
I think I go for a old model jeti controlbox. If anybody has one for sale please let me know.![]()
I don't think you have understood what Boris was driving at. You MUST use the PiclocToolz that is compatible with its partner firmware. In other words, Toolz v.E055 must be used with Firmware E055. Toolz v.HD55 must be used with firmware vHD55. They are not all interchangeable.
Click HERE for a zip folder containing all variants of firmware v0.55 with related Toolz versions. It will solve your crashing problems.
One more thing. If you are using a separate camera operator for the AV200 use vHD55 (both firmware and Toolz). If you are controlling the AV200 from the main MR transmitter, use vE055. HD55 has a problem with Tx commands to proportional servos that makes it essential to use sticks as opposed to rotary controls.
