Naza throttle startup speed
daveleigh
Hi can any one tell me if you can control the Combination Stick Commands moter start up speed? mine seems to be a bit fast it will almost lift off!
F450 Flame weel
thanks Dave
Tahoe Ed
At this point, the answer is no. If you are using 10" props with 4S, you might want to drop down to 8" props.
daveleigh
Hi Tahoe thanks for the reply , I'M on 10 x 4.5 with Sunny sky KV 980 motors. i've got some 9050 3 blades to try ,I will give them a go
thanks again
i've tried form 9"to 11" and never seen any difference in startup speed all on 4s....
are these DJI esc's? Does your throttle calibrate clean in the assistant window? moving throttle to half stick when you hit finish in calibrate? got the throttle trim in the middle or disabled?
daveleigh
Hi Kloner, thanks for the intrest ,it all came as a kit , sunny sky motors KV980. Hobbywing skywalker 20amp esc's ,I got the Naza separatly, the throttle calibrates cleanly in the assistant window as far as I can see, trims 0
I tried resetting calibration with the throttle Half stick but still the same ,a bit to fast!!! I may have to live with it
thanks Dave
daveleigh
Hi Kloner, this is embarrassing ! I did'nt know you had to!!!! I just did what the assistant said and to be honest I'M not sure how to ! any help would be appresheated
thanks Dave
