Naza-m v1 pmu v2 will not recognize tx yellow fashes
brused
problem= naza-m does not see Futaba tx+ 6 channel receiver flashes yellow
Help for solution Please
TX Futaba 6EX-2.4GHZ Receiver-RX-6
Calibrated as traditional, but TX not recognized, Nata-m flashes yellow and an odd red
flash when i try difereant settings on TX.
equipment= Multirotor F550 Naza-m v1, PMU v2 original led or VU ?
Full charge on TX, and receiver sees the tx 6 channel green led and digital
completed wiring for pmu set up very carefully, I see no errors.
channel u goes to channel 5, 2 position switch, yellow flashing, u goes to ch6 Same problem
I would be grateful for help.
Had GPS error and no receiver error.
Gps error possibly not resolved. Assistant software v2.20 firmware 4.x TX calibrated, gimbles.
Thank you in advance
brused
Check you endpoint adjustments. It appears that you are in failsafe or your system is not bound.
Actually you are correct, When it comes to these adjustments, I am in failsafe, Do i need to be in Gps ?
Can you explain this "not bound" meaning, to the software at that point ? or what Ed ?
