Naza-M anf Futaba T14FG
The problem is that I have is that I get the error message in the DJI Assistant.
I seen similar problems before but I tried and Tried and Tried. I spent over a day on just this issue.
I use Futaba T14SG
It is in situations Fasstest-14CH Single G
The receiver is R7008SB in position D (four red flashing then saved by pressing again)
These two are linked and the light turns green
The Reciver and Nazan is then linked by a cable through the sbus port # 8 to X2 on Nazan
VU is connected to the LED and X3 ports
I start the transmitter then connect the battery to the Quad.
The receiver turns green Nazan makes her sound sequence. VU flashes fast red (low power / error) the battery is fully charged
Connects VU with USB and DJI assistant then the error message I show above.
The assistant manager for TX cali so is reciver type of dbus.
I get nothing showing in the software from TX
So there lies my problem. What the hell do I do now?
Tahoe Ed
See if you can get it to work in traditional. The screen shot that you displayed is just the explanation of the various error codes. What does the lower right hand side of Assistant say?
I found a solution today on the whole problem. What I did is to go over to 12ch on transmitter. Use traditional connection between Reciver and Naza and set Reciver to mode B.
I'm not happy with this and will go over to S-bus later when I can get some help on the issue.
PeteDee
Mr take no prisoners!
I decided not to use S-BUS, I wanted to use some channels directly connected to remote switches so just used cables to plug it all together and it is working pefectly, I am using a 7 chan FASST Rx though.
Pete
With that receiver we are out of luck. Older recovers work but this one as I have is a new generation that is talking a new language that the naza don't understand so if you want to have telometry you need to get one of the older receivers that have S-bus(1) the new s-bus is not supported.
So we just have to wait to a new firmware comes out that speak the new language.
