S11D336B
George - Hoverfly
Since I worked with you, I'm pretty sure we figured out what caused the problems you were seeing.  I think it's related to magnetic interference from your ESCs/wiring harness.  The compass would look fine on the ground, but swing all over the place while flying.  Which may be why you were seeing heading changes while flying in mag hold.  Basically, the solution is either moving your power wires/escs/batteries at least 6" from the board or using an external magnetometer.  External magnetometer support is coming soon.
			Iris, are you using steel fasteners? I have the boom clamps you made and can't find an appropriate aluminum screw that will work.
I don't know what else can be messing with my GPS, but I have it on an aluminum post as high as it will go with the supplies wire. If I even have my GPS board attached to my HFP board, I get weird yaw input and can loose control. It also immediately wanders off course when I set it to PH. Like i said, I sent it in and George said it worked fine.
