Sony RX100 with Steadishot switched ON - so hard to tell how well the Hoverfly Gimbal is working.(not doubting, though, that it is working very well
Does anyone know the PWM update rate from the Hoverfly Gimbal to the servos?
We shot this with the Hoverfly Gimbal (Cinestar 8 with Cinestar 3 axis gimbal, Hoverfly Pro, and Hoverfly Gimbal board):
And yes, there is a small bit of post stabilization (why not use it?).
I think that as more direct drive gimbals reach the market, we'll see an improvement. But as it stands right now, the technology is available for making great videos.
VERY NICE. Can I assume you were using Pan Stabilisation too?
Well done mate, that's a brilliant film!
What camera are you using?
Gunter.
Can't find any mention in the Hoverfly Gimbal manualI believe it goes from 50Hz to 400Hz, it's in their manual.
Benjamin, very good video again. I 100% agree, it's same rules as shooting on the ground, it's not gear what makes the films. I see so many clips of zenmuse just flying around on the field in the gusts proving it's stability. Seen that, and already kind of bored to robotic looking footage. It's nice to see high quality footage shot by pro with right movements, footage looks very naturally smooth. Which settings you use in GH2 by the way and did you shot 720p50? I've been very pleased with latest driftwood cluster.
I would like to say that I just spent about 30-45 minutes installing the hover gimbal and I feel like an idiot for going through the Skyline hell! I probably spent over 10 hours trying 5 different firmwares and adjusting things. Then after being told I needed 3 BEC's, 3 batteries, a new power harness, felt washers, shock absorbers and a barrel of luck I got a hold of this thing. I will admit, in Hoverfly style, they over do the literature and it does make it a little intimidating. But truthfully it was much simpler than I thought it would be. I didnt even use the rubber mounts, I just double foam taped it to the av200 and told it the orientation, went through the calibrations and voila! I set my bec to 6.5v and it is just perfect. No creep, no jitters at ALL, very fast, there were plenty of adjustments there if i felt the need to play with them. but all in all this is exactly what I need. I dont need tripod steady shots, I just wanted smooth enough to not induce rolling shutter or headaches when watching. But it is much much better than I was hoping for and that is great news. So hopefully this adds a little more confidence to anyone thinking of getting a cam gimbal that wants something that will WORK! I am not affiliated with Hoverfly, though after flying the new boards I wouldnt mind.Congratulations Hoverfly on making some amazing products. I am still blown away at the smoothness of the .802. FYI, I used 1.03 for the gimbal. It was a little confusing because there is a test 1 at the top of the list which i ignored.
Yuri
I'll be grabbing one of these hoverfly boards. IrisAerial, I've followed your Skyline progress or lack there of so reading this is inspiring. Question is, will this work fine on a Cinestar gimbal?
