Haha this has made me chuckle. Spot on Dave re the failsafes in A2 and WKM.
Ed I hate to differ but are you sure about that?The A2 using the internal Rx will automatically enter failsafe upon loss of signal. However, if you are using another Rx then I would recommend that you set up failsafe as described in your Tx/Rx user manual with throttle above 10%, etc. Unfortunately in the A2 assistant using either the internal Futaba compatible Rx or the Spektrum satellites it will not show any changes other than RC signal lost and that indicates that it has moved to failsafe. I also tested with the Lightbridge and it performs the same and is connect via DBus.
I have emails that contradict that. My own testing of the S-BUS / Spektrum negates ANY failsafe programming
Dave that was my recommendation, not necessarily DJI's. The A2 is a special animal when it comes to failsafe. If you have received specific instructions from DJI and have tested it then I will not quibble and will modify my post. Thanks.
OK All sorted now, thank goodness.
Everything is working as normal now, once I started from scratch, must have been something really weird going on.
I had a nightmare at one stage even getting the motors to turn, as the start sticks seemed to be opposite to eachother, and reversing them on the transmitter seemed not to work, they had to be done in the software.
So for my own recollection if I ever need it I will post here what I did, and what I watched/read to get going.
Futaba T14SG With A2 DS16..
A CH1
E CH2 REV
T CH3 REV
R CH4
U CH7 (gps/atti/manual) 76/76 ENDPOINTS
K1 CH5 REV (Knob LD to set Basic Gains)
K2 CH12 REV (Knob RD to set Atti Gains) Looked at manual and video and there seemed to be a bit of contradiction which channel, so just made it 12)
IOC CH10
Go Home CH11 58/58 ENDPOINTS
Will set the other stuff like leg retracts later which should be straight forward.
I take it you still have to set the likes of minimum throttle points for failsafes etc, same as Wookong.
Anything else I am missing that I should be aware of?
Will add links to pages required to get setup, for anyone else moving to the A2 Futaba..
http://www.youtube.com/watch?v=eMN4xosIpdg (Video to help)
http://download.dji-innovations.com/downloads/a2/en/A2_Quick_Start_Guide_v1.08_en.pdf A2 Setup manual
Using a Futaba 14SG and A2, my system would not show failsafe entry in the Assistant with the TX switched off. The A2 Assistant would only indicate signal lost. The failsafe transition indication did not appear until I programmed end points for them. Tahoe Ed is correct. History being what it is I find it foolhardy for anyone missing the fail safe indication to trust the FC is actually going to enter a fail safe mode.
