not like they never need oiling sealed, they have a metal dust guard on em, about it. sealed like your talking usually have a rubber dust cap, and even then i oil everything on all of em,,,, all except them orange bocas
To check a motors bearings, an easy way is to hold the leg under a motor and spin the motor. if you feel anything, the bearing is shot. if there all smooth but you get a noise out of one motor loud like your vid had, it's most likely an out of balance prop....... I'm not an engineer, but i've found all that true when was getting mine back from trying to kill it. a hot motor that you can't feel the bearings on is definately the one to chase the balance on. alot of times it's the side to side balance of a prop doing it on mine, put the graupners on totaly balanced so they wouldn't stop any certain spot on the balancer made all my motors cold. with the apc, i always had one warm motor.
