Here you go: Gopro @ 1080-50 protune and somepost stabi with the Disco:
Thanks Tom! There is a lot of jello in... specially in strong light conditions. Have ordered a polarized filter and hope that jello is gone then.Another great vid, Meme! Very enjoyable to watch.
Did you had less jello in strong light (sun) conditions using that filter tom?I'm using the filter, just love it. Especially when trying to catch the colors of a great sunset.
Well, the answer to jello first, of course, is to get rid of every bit of vibration as possible. But, yes, afterward a polarized filter helps to keep the camera focus sharper as light does cause interaction. I'm sure others would argue that that is not jello, and I have to agree.
Now, I'm not a camera guy, but I do know what I see in my experience.
Bowley, I can't answer that question, not yet experimented with an nd filter yet, but what a polarized filter does is to reduce the direct light into the lens giving the camera the best capture of true color.
This is something that I learned from my fly-fishing experience. Reduce the light reflections and you can indeed see into water. Nothing reflects light like water does.
This has taught me that if you can reduce reflections into the camera you can indeed get a better stabilization of image.
There is a draw back, as with everything, and that is low light conditions. Images will loose clarity as there is not enough light entering into the lens.
Fortunately, here in Colorado, there is not too many days that we have low light conditions to worry about.
From what I've seen of your vids, I wouldn't call that pausing effect jello. That is more a digital package loss. All these 1's and 0's get lined up into packages we call words. The words then get lined up in the signal coming into the processor. What I see is words getting lost.
This can be caused by light reflections inside the camera, it having trouble processing words to send out into the stream. Or, it can be a cause of the sd card. When running 1080p the stream is a hell of a lot larger and if the processor can not extrapolate the data stream it will reject words form the stream, so it's imperative to use the best sd card you can to collect the data to transmit.
You are on the right thought path, first control the light, then see if the effect goes away, if not try a better card. If it's still undesirable then the problem lies in the camera's program or hardware. Not all cameras are created equal, obviously. Sony uses a very proprietary system, which is why so many people hate it. I, however, have found a Sony to be a pretty solid and well thought out system. But, then again, like I said, I'm not a camera guy.
I had the 2 axis Gimbal from quadframe.com under the Stock F550. Great results for the money.A bit on/off topic here... Am considering hanging our Black under the 550. Are there any gimbals available that can be run with a stock 550 setup??
