great vid.........was any of the dwarf star one suppose to show us anything stable about it? I'd take a $20 kk board with off the shelf firmware before i tried imagining becoming a programer in the dev team and only have her flying that well.
That flight vid was done manually, 3rd person, from quite a distance away as anybody can see. I don't have any FPV or feedback of any kind other than what I can see from 100+m. All the movements it makes are my stick inputs, and I wasn't going for smoothness, I was just flying around, testing it out dynamically. The movements are exactly what I input, so what exactly is the problem? Would you like to see datalogs of input vs. output, so you can see they match up (that is the real measure of a FC's performance)? Keep in mind this is a very responsive
630mm 4 kg octo capable of lifting 7kg additional payload, but which had none on this flight so it's a bit overpowered and it is tuned for maximum responsiveness. It's a bit of a beast. I'm not trying to make excuses for how it flew. It flew *exactly* as it was told to. I was making aggressive manoeuvres to test it out dynamically, this was the first daylight flight I'd had in an open area, everything before that has been hovering in my back yard.
I'd like to know how you can watch a video and conclude that a flight controller is responsible for the apparent stability rather than the pilot. I'd also like to see some video of smoother flying, at distance, unaided, and without a gimbal? Do you have some? Do you have any video of another FC suffer that amount of inflight damage (one half-blade completely gone, and 4-5 more heavily damaged, and a motor tilted over) and not immediately flip over and die. Do you have any video of other VCs doing the bottle test?
Again, I have plenty of video of the thing just sitting there, unmoving. But it's pretty boring so I don't both to upload it. Oh, well here's one boring one, I was trying to see if I could get it to flip on takeoff by intentionally loading up the I-term. There's a bit of flying at the end. Again, all movements are my inputs, I was testing the flying, not trying to shoot Hollywood cinema.
I'm just trying to make this discussion a bit more objective if we are going to be comparing flight controllers. It's a bit ridiculous for anybody to claim that they have judged anything based on watching somebody use it, or based on a given flight video. That goes for any flight controller, not just Arducopter. Because at the end of the day, I think EVERY flight controller available has the whole "stability" thing pretty much licked. 99% chance that if you see one that you think is "unstable" it is the user's tuning which is at fault, not the controller. What really separates the controllers now is ease of use, availability, ground control software, features, robustness to flight failures, and of course price. So why don't we try ranking FC's objectively on these aspects instead?
Where Arducopter suffers is mostly on ease of use. Some users really struggle to get it working properly. It's very powerful, and flexible, it can fly setups that a DJI product can't, but that results in it being complicated to setup well.
I just have to laugh everytime I read that sentence from whatever source, pay a premium price for a board with advanced features but only able to say it flies great in manual mode. Oddly so does my KK 2.0 with the latest firmware and it's about $400 less expensive, seriously...
The best thing to do is rather than just take a list of available flight controller, first define what it is you're looking for and what features are "must have" vs. would be nice to have. the more features, the more expensive and/or complex it will be to get a system up and running with all of the features functioning as they should.
Once you have a clearly defined list of features and functions then research each of the possible flight controllers for how well those features work on that board. If you just publish a list all you'll get is the respondents favorite and how it's better than all the others, many of which they only know by hearsay which could lead to a not so satisfying experience.
Best way to see how well things work is find the forum where that particular board has the most active postings and do some reading, things that are problem areas will be readily apparent as those will be posted about repeatedly. That can also be an indicator of how easy a particular system is to build and tune, if relative newcomers are having a lot of problems then you may want to pass on that system if ease of setup is one of your criteria.
I have at least one of each of all the boards on your list except for the Quad4 which I've heard of but never researched. Whenever I'm asked which is better the answer is always the same, "it depends". It depends on how much or how little you want to be involved in setup and tuning and what you expect from it. It depends if you want superior advanced functions that your use case will rely on to be 100% functional 100% of the time, some are light years better than others. If you have little to no experience and need a LOT of support that will influence the decision as well and you may be better off having a ready to fly system built for you by a reputable vendor that is geographically close so any problems could reasonably be resolved by perhaps an in person visit.
I suggest you take a big step back and start by defining tthe use case and what is most important then go from there.
Thank you! This is exactly what I'm getting at.
Asking on a forum "which is best?" will only return answers which are basically the respondent's "favourite" system. Of course they think their systems is the best, or else why would they be using it? You'd be better off just conducting a poll and just buying the most popular system if you are going to base your decision on answers like that. Just make sure you conduct the polling in a place where you're likely going to get equal representation of users. ie: don't ask on a DJI forum, which is the most popular controller...
If you only want to manually fly a quad, and you don't want to spend a lot of time tuning, DJI is probably the best. If however, you want to be able to fully scripted GPS missions, that is completely customizable right down to what the yaw controller does in RTL... well your choices are limited. (hint: MR users tend to want the yaw to remain where it last was on RTL so that they can maintain orientation. Helicopter users tend to want the nose to point at home so that the tail is naturally flying behind the helicopter).
