Thanks guy's...gonna run down now and see what they have in halfords and hopefully get an half hour out with the sj8 as weather has cleared up.
Hmm... I have the two 2mm mini-doughnuts threaded onto the 3mm bolts either side of the boot mounts (damn I wish I could draw). I cannot see what to do with the 1mm O ring that I had to slide onto the boom. I'm also not convinced that I have the motors sitting square. One problem I find is that the mounts are so beautifully made that if things are not sitting perfectly the 3mm bolts jam up and I can't feel if they are pulling down properly.
C
So where the hell is that 1mm O ring??????
Will cross my fingers for you Dave,Hopefully then its coming my way!
Thanks Andrew, I'll give that a goHi Bluerex
The thin o ring is supposed to go on the boom and between the upper and lower engine mounts just before or after the locating hole in the boom. Linda explained this in a previous thread. It's an added anti vibration tool. They are then pinched between the upper and lower engine mount. But on the XM's I have built to date the o ring for the engine mounts has only been around 0.5 mm I suppose they could be bigger on the SKYJIB.
regards
Andrew
Hi Bluerex
regards
Andrew
Can I ask, if you were to do the build again, is there anything at all you would do differently? I'm thinking kit list?
You mentioned early on, I think in your youtube part 1, that you hoped you weren't going to regret being the 'guinea pig' by going with the new AXI 2820 Droidworx edition motors. Do you still think they are the right option?
Steve
I will still be able to get my pole in all sorts of places you can't get your X4!!
