Well I am no expert but I am running futaba R6203 sbus X8 quad. And I dont know if I understood your question correctly, but here goes. Basically the SBUS free up the input of the WK-M allowing you to make it as output for servo/gimbal while the F1 F2 to be converted to motor output making it 6 + F1 F2 8 motors. So one servo lead from RX to WK-M / 6 motor + F1 F2 / T & R (gimbal)
Or did I completely misunderstood your question?
Hello, this is my first post here, so thank you in advance for your support!
I'm building an octocopter and am using the NAZA-M with the updated firmware to use it with an octocopter.
I have the Futaba T8J transmitter with the R2008SB SBus Receiver (8 channel).
Realizing that I have to use F1 & F2 as M7 & M8, I am at a loss as how to run my gimbal now.
You are the first person that I heard a solution from, but I don't fully understand your explanation. Could you explain it in more detail as to how exactly I set it up and what I connect to what in order to get it to work?
Thank you in advance, you are a life saver!!!
AM
