Just did a little research to figure out why I couldn't get the failsafe switch positions to bind to a JR 921 receiver.
Here's the trick!
WIth JR nine channel receivers there is a peculiar step in the binding process to make the switch positions work when the signal is lost
With the TX off, plug in the bind plug and set your switches to the positions that will force the DJI system into failsafe mode.
Power up the receiver and verify the receiver/satellite lights are blinking.
BEFORE DOING ANYTHING ELSE, REMOVE THE BIND PLUG AND VERIFY THE LIGHTS ARE ALL STILL BLINKING.
Hold the bind button on the transmitter and turn it on.
When the lights all illuminate solid, unplug the flight battery and turn off the transmitter.
Go to DJI's Assistant software and verify the bind was successful and that the system will go to failsafe when the transmitter is turned off.
So, the trick is to remove the bind plug before using the transmitter to actually bind to the receiver!!!
Hope that helps.
Bart
			Here's the trick!
Hope that helps.
Bart
