Hello everyone!
I have the DJI A2 FC and iOSD Mark II and with a successful recording of the home point, I have never been able to get the distance from home point to show the actual distance data. It just shows the "D" icon. Also, the direction to Home Point Marker also doesn't work, the marker icon just stays in the middle of the screen the entire flight. So, I upgraded to the new firmwares on all the DJI FC and components and Mark II and still no distance from home point, again it still only displays the icon. Also the new Az (Azimuth Angle) feature doesn't show any data just like the Distance doesn't. I tried DJI Support, but no dice. Anyone else having the same problems?
So, I test flew my rig today with the iOSD plugged in to the port that is on the GPS wire, installed my batteries, turned on the system, connected to 7+ satellites, armed the motors....and everything worked exactly as it should!! Home Point Distance, Home Point Direction Marker and the new Az feature! Finally my faith in DJI is starting to come back. Don't setup the system as the first part of the manual says on page 6 (1.1.2 Hardware Connection Diagram), setup everything as page 38 shows to (2.4G Data Link connection diagram) even if you are not using the 2.4G Data Link addon.
Taylor
