BorisS
Hi Guys,
Now is the time to give AQ6 a try and I am excited ! For the heck of it and already having a X4 TBS discovery I am interested to setup another one but overpowered ( X8 conf) for the fun of it for fast ascends and forward flights. If i understood it correctly the AQ6 has no manual mode with deactivated self leveling, but thats actually what I am interested in knowing that other FC like the naza have issues at full speed flight in self-level mode or straight manual mode shaking up etc.
So lets see how the AQ6 will perform on a dedicated FPV quad tending towards speed !
Components
Frame:
View attachment 7051View attachment 7054
Nice FPV setup since the OSD and clean v regulators for VTX and CAM are in the TBS core and the distribution is in the bottom plate plus current sensor. For those who don't know the frame !
Motors:
8 x Kopterworx KW 2
Maximum load current. (180 sec): 17 A
No-load speed: 840 rpm / V
Recommended Propeller Size: 9" .. 11"
Mechanical power: 200 W
Thrust max.: 1200 g
Wire length: about 40cm
Total weight (without cable): approx 75g
Of coarse the standard arms of the disco will have to be modded. The bottom landing gear thingis on the arm will be cut off and the motor mounts section will be support by 8mm Marklon plates to support the arms and to allow the X 8 configuration. Lets see how much flex is in these dji arms maybe a carbon sleeve will have to give them support or a nano carbon fibre tubes filling will support the structure.
Additionally the plates will allow LEDs in the motors mounts for orientation:
Still have to design a new landing gear for the x8 configuration. Probably gonna use Makrlon again lets see to follow.....
Components
Frame:
Motors:
8 x Kopterworx KW 2
Thrust max.: 1200 g
