jfro
Aerial Fun
I'd highly recomend keeping on that path with the voltage part, the heavier the load the less pack i like using up to give a margin in the flight envelope like your doing
We fly epics on gens ace and see almost a volt in sag, i'll fly it down to about 21.5 at about 6 minutes and land at 22.3-22.5 ish, half packs used. my hex has a bit less sag with all the same but u series stuff, and i do about the same numbers,,,,, were on 20 amp hours of 6s in pairs parralel
the math for a c rating is suppose to be c rating times capacity equals continuous amp rating.... 10 amp hour 30c pack is 300 amp service...
doing pairs of packs vs single packs is a huge weight difference and cutting every gram is the best way to go... nothing in excess
Please let me know if this is somewhat correct.
#1 8 Tiger u5 motors have a rating of 20 amps at 100% throttle with 16" 5.5 props. 8x 20 = 160 amps draw.
Their max rated draw is 30 8x30 = 240 amp draw. max
The new 10,000 mah Multistar has a 10c rating with a max of 20c for 10 seconds. 10cx10amp hr = 100 amps
20cx10amp hr = 200amps
Conclusion, these batteries would not be enough for a 8 u5 motor MR.
#2 4 Tiger u5 motors 100% throttle 16" props 4x20 = 80 amps
max amp of motor 4x30 = 120 amps
Conclusion, this would be enough for a 4 u5 motor MR.
#3
Tiger u4 motors on a hex w/ 15" props 100% throttle 15' props 6x17.2 = 103.2 amps
max amp of motor 6x30 180
Conclusion. Kind of on the edge, but maybe ok if c rating is not fudged and full throttle on 15" props is just for a few seconds. Kind of close on this?
Would appreciate some feedback as to if I'm doing the numbers right.
Thanks in advance............
