jfro
Aerial Fun
My big octo is relatively efficient in the configs I fly. I'm using Mikrokopter electronics, so I have exhaustive data logging.
My copter is an X8 with 500mm booms on a Cinestar-like hub. I have the full MK stack including the "Double Quadro 2XL Cool" power board, KDE 4012 motors and T-motor 16" CF props, and a MōVI M5.
What I see on my machine is a current draw at hover of about 58A with the GH4 (AUW about 22 lbs.) and a draw of 67A at hover with the 5D Mark III (23 lbs). I'm using dual Tattu or Pulse 10000mAh LiPos. The highest current draw I've seen in a full-out climb (not that I generally do that) or an arrested descent is about 110A. In a normal flight for filming purposes, the copter consumes almost exactly 1000mAh/minute, giving me a 15 minute flight time with 25% reserve (although I usually fly 8-10 minutes).
I have a 850mm x8 w/ 3520 Avroto's. I fly 18-20lbs w/ 2x8000 mah 6s 25c batteries. Also a 650 quad with KDE 3520's.
You mention you generally fly about 8-10 minutes but can get around 15 minutes. I have similar situation and am curious as to what you think the overall effect on battery life is when you fly @ 8-10 min vs 15 min. Last year I pushed the crap out of my 5000mah 4s batteries and some have held up better than others.
Some of the experienced fliers on this forum have mentioned that by not going below the 3.65 or 3.7v range while in the air will greatly increase your battery life. I thought the 80% rule (80% of 4.2v) would be 3.36 so last year I set my alarm to 3.5.
I built a new quad and x8 with 3520 kde and the avroto 3515's this year planing on being in the 15 - 20 minute for the camera's each would carry. This was based on running close to the 80% rule. Following advice of others, I've been experimenting with landing in the 10 minute range. So far my batteries look great and my charging times are reduced, but I'm not 100% that I'm not being too cautious for the sake of my batteries. This year my 6s 25c batteries land so much cooler than my 5s did last year, that I'm guessing this has an impact to.
Do you notice much of a temperature difference between your 10-15 minute flights and if so are you concerned about the heat?. Do you feel the 15 minute flights are shortening the life of your batteries as opposed to what you'd get flying mostly 8-10 minutes?
Be interesting to see total flying time on wearing out a battery that wasn't abused. Say 100 - 10 minute flights for a total of 1000 minutes verses 66.6 - 15 minute flights for a total of 1000 minutes.
Enjoying this battery conversation. Still interested in peeps opinions on how much overhead is justified and is that brand specific.
