anaka HL build
anaka
so finally i have something to show
as ever this is what blackmagic filmed
no post stabilization
just cutted
the encoders really improve overall results and performaces
anaka
SamaraMedia
Interesting "turn" of events. Look forward to seeing your Alta'ish footage. How's your COB, what batteries will you use underneath as counterweight?
anaka
hi guys, basically the elements are the same of the standard bottom-gimbal config
i just biult a flat landing gear with a space for batteries inside and a new upper plate that in the bottom-gimbal holds batteries
and in upper-gimbal holds the gimbal
plus i repositioned the GSP antenna, compass and super-buzzer in a neutral position for both configurations
all the balance and weights are the same as before and the flight looks basically the same...so all looks fine
the only things that are giving some problems are the moments of taking off and landing....motors are too close to the ground
so in the take-off if I use the VARIO option I can see the drone stay in the ground for a while then he takes-off very quick then slows down to the regular ascending speed; with manual control things are a bit better couse I can manage the power directly so I can reduce the "push" effect
in the landing moment I have a wierd "bouncing" effect, in both VARIO or manual control when I approach the ground the drone starts to go very close to land then climbs a bit by himself than tries to land then climbs again
I made just some quick flights without drain all the battery, so no emergency landing at the moment, but have to say that it was impossible to land with the VARIO activated, I ever had to deactivate it when I was far enough from ground, then land in manual mode
BTW the landing ever was a bit rude...i have to add some dampening to the new landing gear and improve manual landing skills till Mikrokopter consider this issue
who knows if Alta has the same problem..
anaka
new staby test
as ever just cutted, no post stabilization
i focused on the 3 basic motions:
pan test
forward/backward test
climb/descent test
and some hovering..
anaka
no this is the gimbal-DOWN setup
the gimbal-UP is till in development but honestly i feel it should be exactly the same
anaka
Hi people here it comes the latest effort, i used not only the drone but some other toys as well
