anaka HL build
anaka
hi jwoike. yes the 3axis gimbal too, all the frame structure is from quadframe
hi MikeSF the foldable frame in a coaxial setup takes less space by itself, if you fold it you just go to save even more space...for transport in a car for instance
you decide when you need to fold them so it's up to you how often you need to use the folding arms
personally i just assembled it and didn't used the folding arms at all, this becouse i fly in my garden when i'm in development
will tell you more when i'll start to trasport the rig
if you mean how quick can be folded and unfolded it is less quick than a dji s1000 but it is much more stiff linkage when you flight, that is really much more important for me, safety fist!
anyway you just have to lock and unlock some screws on this frame to fold-unfold arms..nothing complex, you use just one screwdriver, i personally prefer this solution, i feel it very clever
for now i can tell you that the materials and the machinery of the frame in all it's parts are well done and robust
they are well minded and if you ever had occasion to build you own frame you can feel that Jakub from quadframe is givin a very good product at the cheapest price possible for that quality and materials
in my opinion this is a best buy
Mike SF
Banned
Thanks for the update. I agree that their folding mechanism is very safe and strong, so good for flying. Since you need access to the screws and nuts from the top and bottom, it's nothing you probably want to do a lot of times. And you have to make sure your build allows access to the screws. But for an occasional flight, it would be ok. I will keep this frame in mind.
anaka
Hi Mike
just to explain better
to lock unlock the folding arms you need just one tool...the nuts are fixed on the frame, like in cinestar frames, so you access only from top and use only one screwdriver
very clean and fast ;)
in my setup i locked the ESCs to the arms so i saved space on the central frame, this let's me access quiclly the screws for the floding arms
and at the same time i cool up the ESCs with the airflow from the propellers
Mike SF
Banned
Ah, that's important that the nuts are fixed. Makes the folding much easier. Thanks!
I also like to put my ESCs on the arms: better airflow, less crowded between the plates, and short wires save weight.
anaka
here some quick tests with GH2 and Lumix G X Vario 12-35mm
raw data, just cutted and posted
some flights were in windy conditions, with strong gasps, the stabilizing level remained the same
total flight weight 7Kg
anaka
thanks stevemaller
as you can see by the pictures i made my own power distribution board, based on quadframe electric plates
then I dressed all the mkbl 3.0 in a very personal look and used the futaba connectors in the place of molex to connect the I2C to the flightcontroller
all works fine and KDE motors are fully supported by this setup
stevemaller
Heavy Lifter
thanks stevemaller
I'd like to see how you connect the Futaba connectors to the Flight Control board. Thanks!
I use the same exact motors on my X8.
anaka
main.php
on the square 13 you can see the D and C connections for the I2C, then you can use the Ground connection on square 7
and that's it for the FC board
main.php
on the MKBL 3.0 bottom side you can see the I2C connectors (top right of the picture) there you have the same 3 connections
C - D - Ground
i soldered a tipical 3 wires servo cable with futaba connectors to MKBL 3.0
i did the same on the MK flight control board
for the distributin of I2C signal from FC board to BL boards I used a single 3wires servo cable, i soldered the necesasry 3 pins connectors at the right distance to meet each BL board
all worked at the first shot!
there is nothing hard to do, it's straight forward :D
crayfellow
Hi @anaka. I am building a QuadFrame hex so it has been great to look through your build! Are you powering your gimbal and vtx using your main battery and a 12V BEC (as opposed to dedicated 3S for gimbal/vtx)? If so, which BEC and how is it working for you?
anaka
hi crayfellow
yes i'm powering all the system with one battery, to save weight, and i have more than one BEC
let us know how is going your setup! ;)
crayfellow
hi crayfellow
thanks!! One more question- you mentioned more than 12V for the gimbal, then adding another regulator for vtx. Why would the gimbal/controller need >12V?
You should ask Jakub what he suggests for that gimbal. Many run at 4S to give the motors all the juice they need.
anaka
as motopreserve says
depending on how heavy is the load on the gimbal
you need more than 12v to have the right stability
crayfellow
you are right, the gimbal I have on the way is quite happy with 4S, so I would set the BEC around the 16V range, then use a smaller pololu 600mA regulator for vtx and fpv pilot camera if any, and maybe LED's.
anaka
consider that I use 13v on gimbal with a gh2 camera and 12-35 gfx lumix lens that is quite heavy setup... don't go to high with volts if you don't need ;)
crayfellow
what about GH4+metabones+70-200/2.8IS :)
(don't worry, I'll only be flying with 12mm prime)
anaka
new setup with latest KDE 18" foldable blades and new X-quad configuration
less mototrs less weight more efficiency same stability and performances
recently this model received the Official Certification for operations in Italy and now is ready to work in the respect of the law
