that was zoomed into the last powerup on the big file he posted..... it is showing motor outputs on #2 and 5. the y being so different is the problem. all i did was enable motor 2 and 5 because when i enabled them all those two really stood out as not being overlapping ie pushing on each other, the other picture is that same point in time but see how even they all are? you want all those as close as you can for best performance, makes all the props change there torque quickly so when the fc sends a command, the aircraft responds. Ever been around a multi that revs like crazy when in wind or descending? that's usually uneven motors.
In his case he is dealing with a frame i have years of experience with so have been fine tuning them for a while and this is the secrets to that "working out".
for whatever reason when i use Grab on my mac it is not showing that column, guess cause i'm clicked onto grab and not that window.
no problem, i enjoy sharing or wouldn't be here
