teecee
A little confused regarding hooking up my Z15-5D to my A2.  Currently I am using the A2 onboard RX for my flight tests and all is well.  Eventually I intend to move gimbal control to a separate TX but for now I just want to get it up and running with basic functionality with one TX.  Gimbal boots up nicely and I updated software and firmware in assistant software.  I hooked the Can-Bus (Can 1) from A2 to the Zenmuse 5D controller and ribbon cable from Zen to gimbal.  Is that it?
The 5D assistant software is very basic and I see no response there when I adjust TX. In the A2 assistant software there is gimbal control settings but it appears to be for 2D servo gimbals and not for Z15. When I hooked my H3-2D gimbal to the Naza I remember NOT turning on gimbal settings in the assistant as it was all DJI and relatively seamless. Here I have no com between the two so far.
Questions:
-What channels do I map to Z15?
-Can I do this all with onboard RX or do I need to get off my butt and install my futaba RX?
-Does the com for the gimbal all go through the Can-Bus or ...?
Help!
Questions:
Help!
