Getting the bluetooth board to work.  . . . with VX5N V2 Gimbal
When I saw the bluetooth interface board on GotHeliRC I jumped and was attracted to the ability to move the drone around during the tuning process without having the interface wire between the computer and the gimbal.
I used information for the installation from the Aerialpixels.com site, listed under Support.  The configuration of the PC was shown and worked as described, setting up the bluetooth COM port.  The bluetooth board installation, using the harness provided by Vu was pretty simple and logical.
But, when I fired it all up the computer seemed to be communicating with the bluetooth board according to the LED on the bluetooth board. However, the GUI program would not respond, and there was no link to the gimbal.  The correct bluetooth code is 0000.
I delved into the AlexMos blog on the Aerialpixels.com site to see if I had company with this problem.  One poster said he got his to work by reversing the cabling, exchanging the RX and the TX wire connections on the board.  That seemed like an unlikely fix, but I
tried it anyway, and IT WORKED!
I hope this helps someone get hooked up, bluetooth wise.
I'm using an NEX6 with a Sigma 19mm f2.8 EX DN lens which is extremely sharp and fairly distortion free. It has support in the Adobe lens profiles, btw, which is helpful in Lightroom.  If you've never tried a prime lens in place of the kit zoom you will be amazed at the sharpness. It costs $199.
