I am upgrading now..![]()
i didnt know that i can tune the ATVs...!
lol...! is this on the manual??! i only put expo.!
Also what does taht mean???
2. Altitude hold slew center point is now set when activating altitude hold.
That the 0 of the AL is where you have the throttle??
In order to be sure i am telling you what i did in order to tell me everything is ok..!
1. I did remove the trims from My TX in order to do the AUTOLEVEL setup again..
2. download new setup and firmware clients
3. i upgrade to 4.6
4. i did the AUTOLEVEL as per the guide (DISABLE TEMP AND ACCEL AND RE DID THEM)
5. Checked the AL AnD AH switch they are working
6. Checked that i can change AL and AH gain..
7. SOmething i forgot??
Thank you
What about the proccedure???! of update did i forget somethingSo, the Gain (How much a certain feature corrects for disturbances) is defined by the ATV / end point adjustment in your radio. If the gain is too high, you will get oscillation. If it is too low your multi-rotor will float about imprecisely.
http://www.hoverflytech.com/uploads/HoverflyProUsersGuideV3.pdf
starting on page 56
For altitude hold slew, 0 climb / descent is set as the throttle position you engaged altitude hold at.
PaNt... I run (in manual mode) 60% on roll and pitch ATV. I think it is a good place to start for you. Control response is a personal thing and varies from machine to machine. You want a machine that is stable (HF gain setup) and also a machine that is not twitchy on the controls - rolls + pitches too fast to your stick movements. That is where the ATV on roll, pitch and yaw come into it.
Yeap is this somewhere in the manual???
Also when you say Pitch you mean the throttle or the elevator?? because i see you write roll yaw and pitch and NO elevator..!
I didnt know that i can change the ATVs!
Yeao iknow...!! but i didnt know for the HFP that i can change the ATV of AIL ELEV AND YAW>..!I don't know if that is in the manual - it is just part of r/c setup on planes and helis and multis. Just part of learning.
Roll=aileron... tip left and right
Pitch=elevator... tip forward and rearwards
Adjust the ATVs on the transmitter.
The throttle ATV setup / calibration should be sorted with the Hoverfly Setup. https://hoverflytech.zendesk.com/en...-setup-your-throttle-range-on-the-hoverflypro
I ran some more tests yesterday (first time in clear air space at the local field)... Nothing I did (except for running the gain so low that there was really not much holding going on) would stop my craft doing exactly what yours is doing. The F550 now has nice bouncy pool noodle landing gear so I have not broken anything but sadly there is is no way I feel I can trust this controller on my new DW XM.Hi i did some testings, and for now AH switch both in software and OSD shows that it turns on. With only board connected to PC i lifted it from ground to about 2meters and it showed altitude change, and also passed diagnostics.
On our yesterday tests there was no sun at all, we tried also few night shots. Same situation, AH switch makes craft to drops. Its weird because AH was working great on 4.3.860. Now i will try put old firmware to HFP and do calibrations and test flight.
C
Thanks tahoe this makes three of usMy tests of the AH in 4.6 so far also has the rapid decrease in throttle when switching AH on. I turned the gain on AH way down and it improved. I tuned for one flight through, so more tuning might be needed.
I wound my gain down to almost nothing and this certainly fixed the "plummet" effect, but there was not much difference to leaving the switch off altogether...
C
