Thank you for the link. I want to buy the 10900, not the 11000, but I'll definitively check on forums about the results people have with them.
http://forum.freeflysystems.com/index.php?threads/what-batteries-are-you-using.228/page-4#post-3966
Hi Boris and Lanzar,
I know that RTF builds would be the best way, but I can't make money out of thin air. So I just have to take the risk and hope that the people putting it all together make it work. Of course I'll try to get all the parts from as few shops as possible, or even get everything from one shop, so that they call help me select all the right items to make everything work smoothly together.
So XOAR 15x5" are the way to go with your KW10 Pro and CS8?
Why should I take the MX-16 when I can control the camera functions all over remote by the REDmote?
... Please keep the discussion at the polite level which I enjoyed so much on this forum ...
You may want to check with Hoverfly if those Maytech ESCs are compatible. I know the Turnigy Plush ESCs work because I use them. I've also read that the Castle Creations ESCs work with the updated firmware from CC.
With no experience in flying, or building, you want to put together (yourself) a highly complex flying robot, learn to fly it, stick and expensive camera on it, and fly in 4 weeks?
My point is simply this. Your actions, my actions, affect each and every one of us directly. Please consider subcontracting.
I considered contracting operators with an octocopter when the project was planed, but due to contracting cost of above 4kUSD, I got interested in a purchase.
I will never risk the health of people, and I've seen enough irresponsible behavior on sets not to go down this road. I can understand all your warnings and don't take them lightly.
My flight controller cost $1500. My frame $1600. My motors and speed controllers $600. My gimbal and stabilizer $1000. My batteries $1500. My Radio controller $650. My public liability insurance $800. My propellers $300.
My spares on hand $500. My charge station $400. My video Downlink and ground control station $400.
I'm set up to lift a little handycam. Best of luck getting a Red Epic rig for $4K. No disrespect, but your budget needs doubling to do It properly.
... or, of course, have spend 8kUSD and have a lot of small broken pieces.
thank you for the info. I'll take the TURNIGY Plush 40amp Speed Controller.
A reflashed esc is pushed harder and all the safety features turned off. Some hardware have different tolerances some fail some do not.
anyways...what I dont get from reading all this
which pilot in the world can fly a heavy lifter and is not even able to choose the correct prop size for a certain motor? why dont you ask your pilot to order the stuff..he would be stocked to fly the gear he is choosing, right?
or would you be into flying components that are put together by somebody else who googled for a few weeks![]()
flashed esc can stall certain motors on certain voltage/cell combinations...never heard of any problemes on big copters (the stalls happen mostly with the smaller pancake motors)
