UPDATED!: Gremsy gStabi H6 initial Thoughts & Handheld Test (Video)
violetwolf
I've found the Xoar props lose me a little flight time compared to similar carbon blades. After a LOT of $ I've found the Foxtech Supreme Lites to be smooth quiet and best flight times :)
SleepyC
www.AirHeadMedia.com
SleepyC
Is that the Falcon X8 with Tarot FC?
SuperX, but yes Falcon/Vulcan X8, Avroto 3515's Spyder 50 Amp esc's..
Also, was able to make a tiny cord (red and blue) and run it to a 4S pack to power the BMPCC which made the camera last 4 hours instead of 15 minutes. :D
Hi there,
I,m having some problems assigning the Tx channels to the H6.
I'm using a Futaba T8J , I had it working in the past but something is not connecting with the Tilt. I can see on the tx screen that it should be chan 2, its set on 2 on the assistant and nothings happening. Got a shoot tomorra and can t get this guy to lock in unsure emoticon
Pan is working without a problem. I can see the input moving in the GAssistant but no reaction..
Ok, going to sleep now, nothing good comes from late night trials but hopefully somewones around before tomorra!
Thabks
PD: Sleepy C, you don t balance charge your batts for quick charge?(the photo)
Motopreserve
There were recently some updates that addressed some of the Rx issues people were having. Make sure you have the matching software for the firmware you're running. Gremsy is also great about Skype calls for tech support. Give them a shout.
