[FONT="宋]GEMINI Dual-Redundancy Autopilot
Excellence Beyond Safety
GEMINI Multi-rotor Stabilization Controller
Zero UAV GEMINI multi-rotor stabilization controller is a complete flight control system for various multi-rotor platforms, for commercial and industrial AP applications. It opens an
unprecedented era of dual redundancy flight control systems.
GEMINI comes with Master Controller and Slave Controller, included two MC(IMU inside), two GPS/COMPASS, which ensure safty by auto-switching the control to the other one whenever
one occurs out-of-control; The ground station is monitoring the status of two cotrollers, and warning users whenever any one device occurs error of switching to the other one and keep
normal working, which greatly increase the safty of almost none accident, which highly improved the stability and reliability of your flight.
Its high performance antenna, low noise anti-interference front-end RF design, accurate position and speed calculating, represent comprehensive technological breakthroughs. These
combined features make the positioning performance of the GPS near perfection; With higher accuracy performance, larger measuring range, and a unique damping design and calibration
algorithm, the MC(IMUinside) is able to provide stable output even in high vibration and large movement environments. Based on the technology and design philosophy of Zero UAV YS
Series of high-performance controllers, the GEMINI offers you a brand new flight experience for safty ensured. The GEMINI adopts a full metal case design and utilizes high quality
components precisely calibrated with temperature compensation in all gyros and sensors, industry renowned flight algorithm in flight control and UAV field
FEATURES
*GEMINI-M/GEMINI-S CAN BE SEPERATED TO WORK INDEPENDENTLY ON DIFFERENT AIRCRAFT SYSTEM
* COMBINE YS-S4 TO BE DUAL REDUNDANCY AUTOPILOT
*SECURITY ENSURANCE AND GCS ALARM
*AUTOMATIC PARACHUTE OPENING IN EMERGENCY
*AUTOMATIC DODGING LANDING GEAR
*AERIAL ROCKER-ARM FUNCTION WITH 256 WAYPOINTS AVAILABLE
*INNOVATIVE HIGH STABLE FPV MODE
*SUPERIOR ENTIRE SYSTEM PERFORMANCE
*AUTOMATICALLY FULFIL MULTIPLE AERIAL PHOTOGRAPHY MISSION
*SUPPORT SHUTTER OF MULTIPLE CAMERAS
*MOBILE/TABLET/PC AS TERMINAL GCS
*DATA CONFIGURATION ON HANDHELD DEVICE AVAILABLE
*SERVO GIMBAL & ZERO UAV BRUSHLESS GIMBAL STABILIZATION
*BUILT-IN DAMPER,ENHANCED DAMPING FUNCTIONALITY
*MONITOR REAL TIME POWER AND VOLTAGE (POWER CACULATION MODULE OPTIONAL)
*EXTENDED WITH DATALINK (DATALINK MODULE OPTIONAL)
*9 TYPES OF MULTI-ROTOR AND A CUSTOMIZED MOTOR MIXER
*MULTIPLE FLIGHT CONTROL MODES/ INTELLIGENT SWITCHING
*HIGH ACCURACY AND INTUITIVE FLIGHT EXPERIENCE
*PRECISE POSITION HOLD AND WIND RESISTANCE
*INTELLIGENT ORIENTATION CONTROL (IOC)
*POINT OF INTEREST (POI)
*128 WAYPOINTS GROUND STATION CONTROL SYSTEM
*ENHANCED FAIL-SAFE AND AUTO GO HOME/LANDING
*MULTI-ROTOR ONE-MOTOR FAIL PROTECTION
*SUPPORTS ONLINE FIRMWARE UPDATES
TECH Specifications
Supported Multi-rotor
Quad-Rotor: +4,x4;
Hex-Rotor +6,x6,Y6,Rev Y6;
Octo-Rotor +8,x8,V8
Supported ESC output
Common PWM
Receiver Supported
Futaba S-Bus and all commen receiver by adding the conventer module
Recommended Battery
2S ~ 6S LiPo
Operating Temperature
-5°C to +60°C
Assistant Software System Requirement
Windows XP SP3 / 7 /8
Other Zero UAV Products Supported
Z2000, Z1400, OSD, 900mhz Data Link, E1100, HighOne
Flight Performance
Hovering Accuracy(In GPS Mode)
Vertical: ± 0.5m
Horizontal: ± 1.5m
Maximum Wind Resistance
< 8m/s (17.9mph/28.8km/h)
Max Yaw Angular Velocity
150 deg/s
Max Tilt Angle
35°
Ascent/Descent
±5m/s
Electrical & Mechanical
Power Consumption
MAX 5W (Typical Value: 0.3A@12.5V)
Built-In Functions
Built-in Receiver
Multiple Control Modes
3-axis Gimbal Supported
Servo Gimbal Supported
Low Voltage Protection
Intelligent Orientation Control
Vibration Alarm
[/FONT]
