Motopreserve
Sorry, I thought you had said you clipped the red & black servo wires from the ESC. They are unnecessary for opto esc. I don't know that they harm things - people go back and forth about this. Leave it for now. But if/when you remove them - make sure they are isolated so they don't short anything.
The superx should be getting power directly from the PDB. Nothing inbetween. No regulator, no UBEC. Just a straight run from the power. It has an internal BEC to handle the power. Maybe this is your issue?
If the motors are twitching, they certainly have power. I was talking about signal current, sorry. If the motors are twitching with a slow beep - it means they are not recognizing the signal flowing from FC (or in this case the Rx directly) through ESC to the motor. This is the issue I had with mine - but again, for me it wasn't an issue with the Rx/throttle calibration - since the signal was be coming directly from the Rx. My issue seems to be a SuperX problem sending enough signal to the ESC/motor to let it know it's ready.
Make sure you have the servo wired correctly, with the white signal wire on top row of the Rx?
That's all I've got....
