Not I.....
~T.J.
Ok. If you followed the old X650 threads on RCG you'd understand.
Jeff
Posted using Tapatalk
Not I.....
~T.J.
Anything that increases safety and prevents possible injury is a good thing in my book. People make mistakes. If you ignore that fact then your product won't be as safe as it could be. It's not exactly a big deal to program that safety feature in to the flight controller.Why change something when the problem is the radio was turned off first.
Jeff
..........inflammatory statements removed by the moderator..........This is about making complex systems more robust and safer. If the eyesight of one person is saved by a simple change in code, isn't that a very good thing? ..............more inflammatory statements removed.......... BTW, just two weeks ago one of the most experienced RC plane pilots at our club lost two fingers in a prop accident. So don't think your experience or attitude make you immune from accidents.I was flying planes long before flying multicopters. Planes don't have a flight controller. The flight controller is you. The procedure is always turn your radio on first and turn it off last.
Just to circle back and provide an update!!
Using a Taranis, Super X using SBUS, and an X8R receiver, FAILSAFE WORKS PERFECTLY!!! Yes, using SBUS.
Steps:
1. Setup everything possible in Companion9x you normally want. Set Receiver mode to D16 for the X8R, and Ch1 thru Ch16.
2. Click on Failsafe tab and select Custom.
3. Put Ch 6 on 100% (this is the rub in my case as even though I did it, it did not work).
4. Save EEPROM to radio.
5. Bind RX and TX together. DO NOT SET ANY FAILSAFE ON RX!!!
6. Now, to fix it up! On the TX, go to the Failsafe setup. It will be in custom already, so skip to SET and press ENT.
7. Minus down to Ch6. If your's is like mine was, it was not at +100%. Press ENT
8. Now move your RTH switch you setup on the radio to the RTH position and make sure it is showing +100% on the bar.
9. Press and hold ENT to commit changes.
10. Exit back to main screen. Power cycle TX and RX and test.
Now if I read the model into Companion9x, it all looks fine. If I make any changes and write to the EEPROM, everything is updated EXCEPT the failsafe. After writing to your Taranis each time, repeat steps 6 thru 10 and you will be set. Even if Ch6 shows 100% after a write, still repeat steps and save or it won't work. Must be a bug in Companion9x?
Hope this helps someone! BTW, I am using Super X with Stella, as well as the FrSky 4 CH SBUS Decoder. ALL 16 Channels work on SBUS, along with Failsafe!!
Regards,
~T.J.
Works great T.J. Thanks for that.
And while I've stirred you up about safety issues - how do you feel about the inclusion of a geofence? XAircraft doesn't have that function and I think it's a great idea to limit the ceiling or distance your copter can go as they have in the APM/Pixhawk and DJi's Wookong.
I just came back from a 16 min flight with my hex and SuperX in the wind. It was incredibly stable. They certainly have the flight capability down. So if they just add a few features it would be a big bonus. Regardless great value and very stable flight. Good fun!
That's great T.J I'm thinking the test is now to turn on SuperX get a bind X8R goes green and then turn off the radio, what does the LED do?
The thing that doesn't seem right to me is you redoing the failsafe whenever you burn new to the eprom, I don't know about you but I am forever modifying my eepe adding stuff fixing setting, and I have never redone the failsafe, I know mine works because when I turn the radio off the LED flashes the same red pattern that I have when I go RTH.
Anyway I dug around and found the X8R instructions I have attached here the relevant section, still if the way you did it makes you happy then that's cool just so long as you are getting the right feedback of failsafe
Failsafe with Taranis and X8R only gets setup in the TX not in the receiver!
That was before the latest tx and rx firmwares.
Once you have bound the receiver you can "set" failsafe from the TX.View attachment 21853
I guess i should have specified if your running OpenTX 2940 and you have latest firmware in receiver and TX. From what i remember reading that those instructions were for Frsky factory software not Opentx 2940.And how does this support your original incorrect statement?
X
You're flying a dead horse? :highly_amused: No, wait, you typed, flogging a dead horse. Damn, I need to get these new glasses checked..
Jeff
By chance are any of you folks running OPTO ESCs?
