I had some shaking problems in my YS-X4 and solved it changing the SWAY COMPENSATION value.
Just change the value little by little until you get a stable hover.
Thanks I will do that but how do u fix the flipping can u give me ur gains thanks
hi geredop
i think the Gemini and YS-X6 P are similar in functioning. cause the firmware is the same
so i can say for Gemini, in the latest manual on page 45, for Return Home and Land it says
" During RHL, the aircraft will not accept any Manual intervention" i guess meaning no control by Tx
" the Gemini will allow you to provide flight inputs to adjust the landing area" meaning i guess that u can give aileron and elevator inputs to make suer craft lands on level ground.
" If you need to cancel RHL and landing procedure, you can move Ch5 Tx sw to Posn 1, ( Manual Mode )
So if you which to cancel RHL anytime after activating it,,, just put ch5 to Manual Mode.
As far as waypoints are concerned,
on page 42 it says
" NB: In phone remote control mode, Transmitter Control will not work".
I do remember that in the previous Manual, it was clearly written that once automatic waypoint flying starts,
and now if u have loss of communication, then the copter will complete the waypoints and hover over the starting point.
However
this is not mentioned in the new manual, or at least i have not been able to find it.
Will send e mail to zerouav on this issue,
and put up their comments here.
Hleoo guys my zerouav y6 giving me motor imbalance 150 and it does not start motor s keep peeping any idea how to fix that i had just 1 flight with this and it stop working it started when i was calibrating my ESC got T- motor esc and motor by the way when i pull up the throttle all the way it only shows 90 and when i lowering it it shows 7 if that cause it i am lost i spent 3 days but could not fix it tied different ESC used a programing card but nothing make it work but when i connect the ESC directly to RX it perfectly works
Hi VictorHi,
I think that this ESC is a standard one, not a special for multirotor.
You can use it, but you have to program it.
If you can't arm the motors, it could be because you have the sticks inverted, you should make the step by step configuration process, but the way to test it, is arming with throtle top left and aileron top right.
The voice can't be deactivated, so you can turn off the sound in the tablet, and if you have a battery alert, the tablet will vibrate.
About the voltage low, you should configure the "S" number. If you use 3S LiPo, and you have it configured as 4S, the controller will warn you because the voltage is too low for 4S.
Hope that helps
Victor
