Hi Ken,
would you be willing to share your Setting for the AV 130 on the WK-M ? My tilt axis is working nicely but roll is not doing what it is supposed to. Since my servo from the new AV 130 blew at the first startup i had to use the servo from my AV 200 which got a couple punches before and i think the week spot is the servo. If i could test your settings I would be assured that i have to exchange it !
Boris
I doubt my settings will do you any good, the AV130 I have under the Y6 is my old one with Hyperion servos which is a completely different setup than the new one with Savox servos. I did try the new one for 1 1/2 flights before it went down due to the motors being turned off and it wasn't at all happy with the settings for the old 130. Never did get a chance to try tuning the gimbal settings to get it working right.
Current status of the Y6 project
I'm waiting for parts from two places that tracking says should arrive tomorrow. Somehow in all the testing of the frame over the course of the last 3 weeks with three different flight controllers I managed to do some damage to the landing gear legs of the Droidworx L/G, the other day while working on it on the bench the rear support broke in two. Along with that I also need a couple of the support struts as I busted some in the fall and used the ones from the old L/G to replace the broken ones on the new L/G now back on the AD6. I also ordered another battery mount bracket so I can run dual packs again on the AD6 having stolen the second one for use on the Y6.
The other order is some frame parts that will allow me to reconfigure the Y6 to a flat hex. For whatever reason this particular Y6 frame has a very subtle wobble to it even in dead calm conditions and it has done it to some degree with all three flight controllers that have been on the frame so I have to assume the problem lies within some aspect of the frame and its dimensions. To test that theory I'm going to make it into a flat hex and see if the wobble can be completely eliminated with the WKM controller. I will say the problem is least noticeable with the WKM in calm conditions but when a gust of wind hits it's magnified greatly to the point in a strong enough gust it almost looks like its out of control. That's probably due to the current gain settings I have in it trying to find a spot where the WKM could overcome the frames tendency towards severe wobble in extreme conditions, does really well about 95% of the time, its the last 5% that won't go away regardless of flight controller or settings and it shows up in the video recordings.
Rather than chase the problem trying to modify the Y6 I can quickly and easily convert to a flat hex and see what happens. If the tendency stays then I'll start looking at making changes in the frame dimensions and a few other ideas I have. If it fixes the problem I'll consider if I want to go back to the Y setup and experiment with possible fixes. The other part of the decision is I can make a better comparison to my MK Hexa if the WKM is also setup as a flat hex, apples to apples vs. apples to oranges!
What I think so far, Wookong-M vs. MikroKopter
What I'm finding is the DJI has much better stability in autoleveing mode than MK does, plus it has the ability to turn it off via TX switch, the MK is on all the time. For some folks that may not be a useful feature but it does add a bit more flexibility to the DJI platform.
Camera gimbal control from the DJI controller seems to be much better than MK, combined with flying in ATTI mode I can get really nice steady video from a well used AV130 that has issues staying still when used with either of my MK Hexa. The flip side of that is the DJI didn't particularly like the my new AV130 which has the much faster Savox servos instead of the Hyperions on the old one but to be fair I only had it on for two flights while I was still working out the gain settings for the Y6 frame and didn't spend any time trying to dial in the gimbal settings for it. After the crash I removed the newer AV130 and put it back on the AD6 until I get a lot more comfortable with the WKM.
The DJI GPS is slower than the MK to acquire satellites and doesn't appear to have a battery backup so it has to reacquire each time it is powered on regardless of whether it is a couple minutes between flights or a couple days. With the MK once it has acquired satellite lock at a location subsequent power ups get a solid GPS lock literally within seconds thanks to caching them on the GPS board. The time for the DJI to acquire and lock can vary from a bit over 30 seconds to several minutes, depends on conditions and how many sats are overhead at any given time. I have noticed it takes considerably longer on overcast days. Once the DJI has GPS lock it will position hold as well as MK, perhaps even a bit better, very hard to tell fom just ground observation and I haven't had a chance to do a proper back to back comparison in the field yet. A big plus for DJI is the failsafe mode that when properly setup will allow the setting of one of two modes in the event of a loss of TX signal or manual triggering from a TX switch. One mode is hover where the multi will maintain a hover right where it is when it enters failsafe mode; the other is return to home. In RTH the multi will rise to an altitude of 20 meters and fly back to where it acquired full GPS lock which should be the takeoff point if you waited for full lock before flying. At that point if it doesn't regain the TX signal or stays in failsafe mode for more than 30 seconds it will autoland itself, a very useful feature if you happen to have expensive camera gear hanging underneath.
One big advantage MK currently has is the feature set of the software, it comes complete with the ability to do waypoint GPS flight along with a lot of bells and whistles like Point of Interest that will keep the camera focused on a set location while flying waypoints. Also has a "carefree" mode that will keep the control response as though the frame was tail-in regardless of the actual orientation. Being able to fly in all orientations I find it very distracting and confusing to see the MK responding to commands "tail-in" when my eyes are telling me its not in that orientation so I don't use it.
One area where the DJI absolutely excels far beyond Mk and any other flight controller I've ever used is their altitude hold. Unlike MK its not something you can turn on and off, it's part of ATTI mode, but it works so flawlessly you don't mind the fact that it's always on. You can take off with ATTI mode engaged and climb to a given height and then put the throttle mid stick, the multi will then just sit there with no vertical movement unless there is a VERY strong gusty breeze blowing then it might sink a meter or so but it then climbs right back to where it was when things calm down. Ascent and descent is easily controlled by just moving the throttle up or down and it is very linear in both directions. The amount you move the stick determines how fast it goes up or down and the rate is pretty much exactly the same in both directions as near as I can tell, put the throttle back to mid stick and it stops and stays at that point.
I've only had the DJI flying on the Y6 for a bit over a week now and haven't had a chance to test things as thoroughly as I would like but this is what I've seen so far. For a version 1.0 product I'd give it an A rating, I haven't seen any bad traits or tendency to flip or lose control as I've experienced with some other V1.0 flight controllers I own. Some folks are experiencing problems with overheating of the BEC circuits on the ESC's, mine have all stayed at normal operating temperatures during a couple hours of test flights so far. From a reliability standpoint I'd have to rate it as good or better than MK. From a features perspective MK has a big headstart and corresponding advantage at the moment. DJI has been building autopilot systems for RC Helis for a few years now and the Wookong-M system is derived directly from those systems which do have all the features MK does and then some. It may just be a matter of porting the code over into the multirotor world to give the Wookong-M similar capabilities to what MK currently has, don't expect it to be cheap if they do though.
