olof
Osprey
I am flying a stock ESC and Motor 550 with Naza GPS and a 2 axis gimbal and a FPV cam.
This is what I am getting for flight times and the weight of rig.
These are 3cel Onyx Lipos
Now the max rated takeoff weight is 2400g, but I must say flying a little heavy handles pretty much the same as w/o camera. I would even say that it is a bit better in gusty wind.
With a little post stabilization the video results are nice. The Motors ESC's and batteries are just barley warm to the touch after even 6 flights to the max. It is in the upper 20F temp range here in NH, so in the heat there may be issues, I will find out this summer.
Do you think I am pushing my luck here and what checking procedures would more experienced operators recommend other than making sure all screws are tight visually checking props for any damage.
I tested the return to home feature yesterday and it worked flawlessly landing within 3' of takeoff spot in 3-6 mph wind. Fully loaded 2552g.
I will be testing some Gemfan Nylon/Carbon Mix 10x4.5 props and Graupner E-props 10x5. Any thoughts on 4.5 v 5 pitch for this load range?
I have absolutely no jelly at a 320 sec shutter at 60 fps. All and all I am quite happy with this kit.
I was considering going to a S800 but for now I think I will stick with this kit. I also have a F450 with GoPro that flies very well but the Sony picture is far superior.
Here is a photo of the rig:
Exact specs:
Standard motors ESCs
Naza w GPS
DTXC1878 Onyx LiPo 3S 11.1V 6400mAh 25C Soft Case Deans
Futaba 8FGHS Super 8-Channel 2.4GHz Radio MD2
FUTL7627 Futaba R617FS Fasst 2.4Ghz 7 Channel receiver
MKTRpro Gimbal with dual roll servos, single direct tilt servo, I use Naza to control it and one channel to adjust tilt from the 8FGHS.
CMQ1684L-N SONY Super HAD CCD II 600TVL D-WDR DNR Mini Board
PB0018 8 Channel 800mW 1.2 to1.3ghz Wireless A/V Transmitter and receiver
CMQ1684L-N SONY Super HAD CCD II 600TVL D-WDR DNR Mini Board FPV cam
IKAN 9" Monitor with IDX battery and a voltage regulator for the receiver (IDX is 16.8v, I regulate it down to 12.1v) on a light stand.
NX5N with 16mm f2.8 pancake lens
10x5 Gemfam carbon fiber props. I have ordered a some others to test and balance.
Exact specs:
Naza w GPS
