OneStopRC
Dirty Little Hucker
I have recently got my FPV gear installed on my TBS Discovery, it would seem my GPS is having issues with it a little. GPS antenna is located right above the CG Mark, for those of you whom do not know where that is, it is just in front of the two rear arms. My VTX 5.8 Ghz 600 Mw Immersion is mounted above the front left arm mount above my FPV Camera, antenna facing upwards.
I have also noticed some weird throttle issues too, when descending, it seems like I need a lot more than usual throttle to pull it out of its decent rate, almost 80% of the stick or more. I found this kinda weird and possibly put it down to interference from the VTX.
Questions are.... Where would you locate it? could it be doing these things? cures?
Setup.... TBS DISCOVERY, using the TBS Core for video but not for VTX power.
