Scott Drysdale
Mixmaster
I just came across an interesting article from an industrial electrical magazine about industrial motor vibration analysis and thought this information should be shared here on MRF.
The iPhone iseisometer app will show three separate vibration axes, i.e., x,y and z. Typically the IPhone is positioned on the MR motor arm such that the z axis is aligned with the motor/rotor or bell axial direction.
One focuses in eliminating the motor radial vibration which appears in the x and/or x and y axes.....
But where does that z axis vibration come from? I have been wondering about this for some time now.
Turns out that vibration on the z axis is, for the most part, a consequence of motor axis or motor bell runout. Runout is the result of either:
1) damage to the motor bell or motor shaft, i.e., bent or...
2) Bad manufacturing and/or QC.
In some cases there is a setscrew that can be loosened so that the bell can be re-positioned more in line with the motor shaft. But if that does not work such that bending of the bell spokes is required to realign the bell to motor axis, maybe it is time to toss that motor.... Above situations can also develop as a result of a prop that has more pitch on one side or does not lie totally flat against the top of the bell.
