I've had the exact same problem doing firmware loads on both of the compass boards I have. First, stop trying to do it across a wireless connection before you wipe it to the point the bootloader stops working, I've found it to be problematic even with a hardwired connection so wireless is a definite no no in this case.
For whatever reason the latest version of firmware and/or MKMag boards are rather cranky when loading code. My newest board I had fail at 30 something percent on the first try and then stop at varying places up to about 70 percent. I reset/rebooted everything and kept trying and eventually it ran to completion and the board is now working normally. Not sure if it's something in this version of code or not but I've seen it on three different boards now so you are not the only one to run into the problem.
Use the MKUSB connection with no jumper and the stack powered up by the main battery. Make sure that nothing else is running on the system you're running MKtool on and you can even go as far as to temporarily shutdown any antivirus program you may have running. In one case I had to do the short across C3 to get it to reset but once I did that I just kept banging away at it with repeated attempts to load the firmware until it worked.
Frustrating and not at all what SHOULD happen, but again, keep trying and eventually it will take. I even went as far as loading a previous version then trying the latest again and had the same result although the earlier version loaded on the first try which makes no sense to me at all so go figure...
Hang in there, you're almost over the hill!
