Hi Rob,
I use a Graupner MX-20. I already set a switch for going in Fail-Safe using the Dual-Mixer function, but I'm not sure if was the only way to do that. I set this because it does sound weird to to get in the Safe-Mode by switching the radio off.
Also, I set Fail-safe positions for A, E, T, R in the center for all 4 controls (50%), but this works only when i switch the radio off. If i just switch to Fail-Safe from the switch the controls are still working, and that is obviously correct.
My question was if it is necessary or not to set Fail-Safe positions on my TX for A, E, T, R? It seems redundant to me.
I have seen the DJI manual says to not set Fail-safe position of throttle under 10% because may stop motors in some cases. It make no sense for me at the moment why they said this in the manual since DJI have internal safe-mode triggered by U channel, which seems to override the commands from receiver, anyway.
Any toughs?
Thanks,
Mihnea
