Hoverfly Today's excitement, Hoverfly PRO beta firmware first flights
Status
Not open for further replies.
Rate of climb Altitude Slew. Once Altitude Hold (AH) is engaged in flight the throttle stick function changes to rate of climb. Near center stick, with a dead-band from 40% to 60%, the rate of climb is 0 and the current altitude is maintained. From 40% to 0%, the craft descends at a variable rate proportional to the throttle stick up to -10ft/sec at 0%. From 60% to 100% the craft ascends at a variable rate proportional to the throttle stick up to +10ft/sec at 100%. Returning the stick to the center dead-band causes the craft to maintain current altitude
There is no gain adjustment for Altitude Hold. You can return your switch values to their default settings. The Altitude Hold feature no longer needs to be tuned.
if that happens i'll be swiftly rubbing one out on my rig..... shoulda got that insurance
I'll make sure to turn off the cam,,, no worries...
I really hope this works, last time was a $1000 crawl back to the sky and i consider myself lucky it wasn't alot more.
one more time for the fans
Status
