Cheshirecat
Hi
What are considered the Pros and Cons for and against Coaxial layouts compared with Flat arrangements for Multirotors?
This would be in the 1.5 - 2KG payload class.
Am i right in thinking with a Coax you can loose a motor without gravity regaining the upper hand?
What happens if you loose a motor with a flat layout say a 6 or 8 prop design.
How does stability in the air compare with a good autopilot like the Wookong M say and do they have different abilities with wind conditions etc..
I am thinking about safety for bystanders as well as the expense of breaking things and plaftform stability.
Thanks in advance....
