HOW DO THEY DO THAT? - Product photos
How do they cut out images like the one below?
Whats the best way to photograph you builds?
attachment.php
Aviator
Also using a white card background that hangs off the wall and across the floor helps... Thats how they photograph for sales magazines
As it RAINING AGAIN here I thought I may try and get some of my new builds so Ill go check out the links, and try the tips.
Thanks guys
Just managed to film first flight with my fully tooled up SJLX4 so project has changed from Photography to video!
Now its raining AGAIN!
nytram
Yep photoshopped or something alike .. Did this for a living many years ago now it much simpler...
It's a tedious job to perfectly cut out a complex object like that. The better way is to make either a softbox or a backlit white screen. It takes a lot of experimenting but what you get is a more pro feel when there are subtle shadow details where the object comes in contact with the ground. You cant shine a light or 2 on the subject and get anything worth keeping without massive diffusion. My friend uses strobes and a soft back lie white screen/floor. He gets a really nice soft shadow and the he only has to key out most of the background. One of the harder parts of this is to get details of blacks an still retain the pop of all the other colors. Just grab a white felt or paper sheet and play with it. You will need some gels and at minimum some cheap halogen lights. That probably didnt help though did it?
Something like this would be a great start.
Vojec
If you need a photo is the best way in photoshop using a tool remove background (magic tool) or something like that. Its remove very well and then just add some edge blur to blend enges with white background...
here is screenshot...
Vojec
You are right Iris... if you have colorful background then a little play with lasso tool solve the problem...
Stacky
A simple way to do the photograph is to take a piece of large white paper and attach it to a wall at one end and then let it drape along the floor so you get a curve in the background similar to the apparatus Yuri has shown a photo of. The curve in the paper from the vertical to the horizontal creates the illusion of no horizon. So even if the background is not a perfect white you get an image which appears to have no horizon. You can even go as far as to use white card on either side so that you have made something that looks like a light tent. This will soften the shadows.
plingboot
We often do large volumes of product shots which all need to be cut out.
i have a manfrotto table with a large, curved, rigid nylon surface, I light from below, behind and from each side - you'd be surprised how many lights and how much illumination is required.
this gives a shot which is on an almost completely white background, which I then manually cut out, via a bezier path.
20 years of practise makes this a quick-ish process. We never use any of the built-in short cuts though.
Efliernz
Droidworx have their own white photo booth... (I saw it during my factory visit). Part of the many talents of DW :)
Stacky, I love the idea of the nylon to diffuse the light. never thought of that. There is this stuff we use in the sign industry called sign white. GE lexan but milky white instead of clear or fully opaque. It is designed to take out the hot spots of the lights behind a sign. That would be ideal for a box as back lighting seems to be one of the tricks to getting that soft shadow. Shooting black products is still a game of trial and error. I'm no expert by any means but I have tried it from time to time.
Stacky
I use perspex as a diffuser to shoot through often. The distance your source light is from the diffuser (especially perspex) changes the contrast of the lighting. Further away the light source is from the perspex diffuser the softer the lighting, closer and it becomes a crisper type of lighting. Also if you have detail in terms of indenting on metal etc you can take small bits of black card and move them around on the diffuser till it is in the right place to bring out the indented details.
On my website you will see some shots of whine bottles, whose were done with perspex diffusers. Also there is a shoe shot for addidas which is underlit through perspex. Getting the balance between the underlighting on the shoe shot and the top light came down to making sure the light reading from the underlight was 1 1/2 stops brighter than the top light source. This gives a pure white for the background. Also not seen in that shot is all the black card surrounding the shoes to keep the edges relatively crisp.
http://www.michaelstephen.co.nz
I hope I explain this so you can understand but try this. On a cloudy day go up to a window and with the cloudy sky as the backdrop hold your hand up to the window. Keep note of the edge of your hand and how the light wraps around your hand. Now take a piece of black card and slowly slide it towards your hand but positioned so it will go between your hand and the wind as you move it in. As you get the card closer to your hand you will see the edge of your hand lose the effect of the wrapped around light and the edges of your hand will become crisper and more defined.
I think I should try and shoot a small demo of a simple lighting system anyone can do to photograph their multirotors using a few techniques I use for work.
Macsgrafs
We use an infinity curve made from white material...bed sheets work well. Light from behind & 2 others from the front (at 45 dgrees to object).
Ross
