Hi guys,
I have caught the Disco bug and want to build a TBS Discovery but am confused about which ESC's to buy.
I have read on various forums about the problems with Lazy Start motors using the TBS escs’ re-flashed with simonK firmware (I understand the escs’ are originally sourced from HobbyKing, that concerns me).
If I understand correctly this problem has been around since about last March with no Real solutions except changing end points to throttle or increasing the Motor idle Speed in Naza setup (I feel these are not proper solutions). I also understand that Trappy has sent a sample motor and ESC to simonK to try and resolve this issue.
My question, is it worth using the TBS esc's or should I simply stick DJI, what are the real world benefits of the TBS flashed esc's considering the possible hassle’s involved in getting them calibrated and working properly (if at all).
On forums I have read, the only answer that people seem to give, is, they are more responsive and therefore fly smoother (it is worthwhile). How is that going to affect me using the disco for FPV in a practical sense (It will be not so much used for Aerial photography).
I know this is a long and drawn out question, I hope someone will have the patience to answer it.
Items I have decided to order:-
TBS Disco with Core installed
Naza with GPS
Graupner props 9x5 & 10x5 (which I use will depend on AUW)
SunnySky 2216 900KV (these have same spec as TBS MTs’ at half price and possibly are the same)
Immersion 5.8Ghz AV transmitter 600mW with SpiroNet Antenna
Immersion EzOSD
Futaba T10CHG radio (already have) with FrSky TFR8 SB 2.4Ghz S.BUS FAAST receiver
Security Camera 2000 PZ0482 with additional 2.8 mm lens + GoPro2 with layerlens & sorbothane
Ground station & Fatshark goggles
ZIPPY Compact 4000mAh 4S 25C Lipo Pack (147x44x27 mm, 370 grams)
Thanks and Regards - Bruce.
Naza with GPS
Immersion EzOSD
