First: Corey, am I being oppressive?
Simon. The SimonK firmware has some serious sync issues with "pancake" motors. Some have good results, some don't. No one, including SimonK (last I checked) has any idea why, or can provide concussive info - other than video of it not working. The way to test is to strap MR to table and with prop on 1 arm - throttle up and down very quickly. You'll hear the problem of it exists. Basically the SimonK can't tell the ESC to react quick enough - I believe due to higher weight, therefore more mass to have to spin/switch at high speeds.
BTW: the system can't operate with an ESC any faster than 400. The 600 is for now a marketing ploy, until such time someone figures out a way to utilize faster rates. There is some math that explains the whole thing somewhere on this forum.
You should also try calibrating your ESCs from the throttle channel of the RX - to make sure they are all in sync with your end points. I've read conflicting reports about this too - but with the issue you had, can't hurt.
I dont believe that that the Naza can't handle the 680. I have run it on mine without issue - although I like the flying characteristics of the superx better. There are people running them on larger Hex machines (960?) without issue. It could be a gain issue - but I'm confident that of it is, it's not strictly a craft the Naza can't be tuned to handle.
Good luck and please keep us updated.
